Any Benefit to insulating the doors?
Old Jun 19, 2008 | 04:40 PM
justagoodolboy's Avatar
Well, I have been gathering info and material to finally insulate my cab. I plan to use a form of foil backed carpet padding plus possible an extra pad under the std. carpet. I also plan to use the foil backed stuff up the back interior wall under the window plus up the sides where the jump seats are.
My question is this: Would there be any benefit to glueing insulation inside the doors? I have to beleive it would help, but wondering if it would cause more harm than good as it might hold water, etc.
Anybody got an opinions/feedback? My #1 goal is to quieten the cab.
Thanks!
Old Jun 19, 2008 | 04:46 PM
As long as you don't block the drains at the bottom of the doors and you keep it out of the way of the window regulator it won't cause any trouble. It will quiet things down.
Old Jun 19, 2008 | 05:21 PM
stackx2's Avatar
oh ya i insulated my doors and cab and it is so quiet. before you couldnt hear yourself think with the stacks roaring behind my head now you dont even hear them
Old Jun 19, 2008 | 06:08 PM
PapeCAT's Avatar
can you source that foil backed padding? Is it quieter than dyamat ?
Old Jun 19, 2008 | 06:48 PM
olddodgetrucks's Avatar
thats good if you live out of the rust belt,not good if you do,keeps mosture
Old Jun 19, 2008 | 07:11 PM
Baja's Avatar
I insulated my doors using a spray urethane foam, same stuff that is used in the construction industry. Lay it in, let it rise, harden, and sand it down if necessary. Was not hard to do, but time consuming. I had to make sure the foam did not interfere with the window mechanics. A long tube helps get the foam into the top of the door.
Old Jun 19, 2008 | 07:58 PM
jckdann7's Avatar
I did the home depot roof stuff, and helped a lot with sound. Did the doors and behind the seat. Might do the fire wall tomorrow if I don't have to work. At first I wanted to quite it down but now the heat is here Im looking to cool the truck down.
Old Jun 19, 2008 | 09:29 PM
Alwaysworking's Avatar
alwaysonDTR
i used foam for under hard wood flooring but i dont know how well it worked since i have yet to drive the truck but you get 50 squar feet for 30 bucks
it was enough to do all but the doors
Old Jun 19, 2008 | 10:11 PM
timberfalls's Avatar
Nice pic buddy(always working) installed power locks on my truck and low and behold there was pink residential styrofoam insulation inside the the doors!!!!!!! What a laugh removed and I think she goes faster now.
Old Jun 19, 2008 | 11:04 PM
alwaysonDTR
dont worrie i coverd it up with stock stuff and painted it where i need to.
some more pic's if you look around http://s289.photobucket.com/albums/l..._tab_my_albums
Old Jun 20, 2008 | 12:03 AM
Gutterslug's Avatar
I did my doors last weekend and it mad a huge difference in road noise reduction. I've got some pretty good 6x9's mounted in the doors running off a good amp and it actually made the stereo "thump" a little better too. For the couple hours I spent on it it was well worth it. I used an asphalt-based sound proofing (peel 'n stick) that's very similar to most OEM style stuff but WAY cheaper than Dynamat. Next up is the rear cab wall and side pockets behind the rear speakers. Totally worth it!
Old Jun 20, 2008 | 08:01 AM
Can you share where you got the peel & stick stuff from? All I have seen is the stuff you can get from home depot. Seems the stuff your talking about would be alot easier.
Old Jun 20, 2008 | 07:36 PM
jcmoyer2004's Avatar
yeah gutterslug, i would love to know where you got that stuff and what the price of it was. i'm about to start on the interior of mine and i want it alot quieter. thanks
Old Jun 20, 2008 | 08:12 PM
PapeCAT's Avatar
I too would like to know where you got some peel and stick
crossy
Jan 17, 2014 10:15 PM
xp8103
13
Apr 6, 2011 12:55 PM
Common
May 2, 2007 11:58 PM
kninja
Nov 29, 2005 05:53 PM
HighTen
Jan 24, 2005 09:17 PM
