another twins thread
well i started another set of twins for my dads 92, its a hx35/40 over some funky holset. it has a 20 cm turbine housing, i know a little small but it has a large compressor and should spool quick, he cant stand my 62/s400 on my 12v so he wanted to keep the power right there. im using a flange for the hx35 i plasma gantry cut also the holset bht3 flange, a 3" turbine to turbine pipe and a 5" to 4" exhaust. 14mm rotor head, 4mm cam,fuel cooler,ddp pin ,3200gsk, orings, studs,and the normal pump adjustements,timed a tooth, maxspool 2, 60 lb springs a 2nd gen piston lift pump regulated, con fe clutch, 3.54, 33/12.5, 2.5 inch lift, 24v oil pump,kdp tabbed, currently a set of ddp 4s, but a set of 6x13 in the garage waiting. i will try to get some picks up so you guys can check them out, i finished the hot pipe and oil lines and am waiting on bends for cold pipes.
. Will be s300 66-14 and s400. I'm wondering if I should go bigger
. Maybe the Pro52 over the s4
soulezoo
61
Mar 2, 2014 08:51 AM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
