Another Fuel Drip
Another Fuel Drip
One of my trucks started dripping fuel at the injector-pump.
As best I can tell, it is coming from the forward end of that KSB gizmo, or whatever it is called.
When I put my finger under and against the forward end of it, it comes back wet with fuel.
It appears to be coming from what looks like a brass sort of a nut on the end of the valve-gizmo.
It drips about twenty seconds apart.
If I screw this brass nut off, what all is going to go flying across the gravel ??
I looked here :
https://www.dieseltruckresource.com/...15&postcount=9
: but it only shows the entire assembly as part 37 in the diagram, with no exploded view.
Is there an O-ring behind it, or what ??
Thanks.
I looked here :
Thanks.
That is a pressure regulator, its self contained and there shouldn't be anything else inside. There's 2 o-rings on it, plus there is a staked in ball that could leak also.
Can someone show me an exploded diagram of the KSB, please ??
I like to see what I am fixing to tear apart.
If I un-plug the wire, take loose the skinny line, and remove those two bolts, will the whole unit just fall into my hand ??
If I do remove it, does it just bolt back up, or do I have to worry about a bunch of stuff getting all out of kilter ??
Thanks.
Thanks.
BearKiller
07-11-2022 02:43 PM
dslpwr81
28
01-26-2009 09:08 PM
