Alternator/starter troubles?
Old Jul 26, 2010 | 11:46 AM
  #31
grim's Avatar
i dont have the cruise or AC features on my truck,
id just like to get my batt charging so i can drive. bad timing for this i gotta leave for the yukon in 4 days.
is there a test i can do to see if my computer is bad?
these are regulated by the computer right?
Old Jul 26, 2010 | 02:15 PM
  #32
Onemoparnut's Avatar
Yes the alt is regulated by the computer. Does your speedo still work?
Old Jul 26, 2010 | 02:18 PM
  #33
grim's Avatar
no my speedo is dead but i think its the VSS.
How would i test the computer to see if thats the problem?
Old Jul 26, 2010 | 02:51 PM
  #34
I am not sure how to test it but with everything that you have not working I would put money on it being bad. Might be cheaper and easier to replace it than it would be to make everything work without it.
Old Jul 26, 2010 | 06:58 PM
  #35
Just throw an external regulator on there since you have no A/C or cruise. Info in the sticky.
If the PCM has died, you can make the speedo work again by grounding the ground wire from the VSS. The VSS normally gets ground through the PCM.
Old Jul 27, 2010 | 09:32 AM
  #36
grim's Avatar
hey thanx for all the help everyone. MUCH appreciated.
i just came on here to post that i put in an external regulator and it fixed the problem. so once again, you were right on the money wanna. thanx again.
What else does the pcm control? id like to eliminate as much from it as i can.
Old Jul 27, 2010 | 02:26 PM
  #37
grim's Avatar
oh and also i was wondering where a good place would be to tap into, to get power to the alt when i turn the key.
ive found a couple unused plugs on that side that get close to 12 volts with the key on, but the wires are a bit smaller then the original power supply to the Alt so just was worried about the smaller wire burnin up.
Old Jul 27, 2010 | 08:39 PM
  #38
Any dark blue wire under the hood will do fine.
HOHN
Aug 31, 2013 12:05 PM
imbodie
Aug 22, 2013 05:44 AM
Onemoparnut
Mar 8, 2013 05:03 AM
5.9Excursion
Mar 13, 2008 07:08 AM
Paradise Racing
Jan 18, 2005 09:08 AM
