AC Cycling switch.
#61
Jim,
My A/C quit working some time ago. In fact, if you recall I noticed it the night I met you when you came out to that truck meet. Could this dip-switch going bad be the problem I have also?
#62
JIM,by coming straight from the batt., does this take primary load off of our weak fuse panel? Also i ordered the Bosch relay w/ dioded ,does it wire the same way as your drawing?
#63
Jimbo,
Very possible, when mine was getting flakey I could smack the cycling switch and it would start working again for a short time.
It finally gave up by the I-15 freeway headed to nowhere in 100+ temperatures, this is when I threw together this relay circuit in Home Depot parking lot.
BTW "DIP" is an acronym for Dual Inline Package like an integrated circuit.
#64
Coil polarity is important, If you use a relay with an internal quench diode you want Term.#86 connected to the (+) supply.
Jim
#65
Could someone please post a diagram of the rest of the A/C circuit? I have no power at my AC clutch. from what i understand thus far, I should always have power to the A/c clutch when the ignition is on and the ground is switched. Im wondering if this mod will fix my a/c.
I have Ck the low pressure cut off and its good. I'm wondering how the rest of my circuit will be with this relay mod.
I'm not low on freon.
Also i have no power to my wipers?
91.5 ic d250
91.5 ic d250
#66
91.5 ic d250
91.5 ic d250
I just checked the continuity from the blue/striped wire. Found out this goes from there through the both switch on control and low press switch to ground.
Im most certain this mod will fix my a/c. Still not sure why my wipers are dead.
#69
#70
Jumper the 2 pins using an opened paper clip to start the compressor.
You will have to do this even if the cycling switch had not been modified with my circuit.
Jim
#74
