ABS once again.
ABS once again.
I have kind of narrrowed my lack of antilock to either the computer or the diff/ring sensor. Can I hook up a meter to the plug to nowhere (rolls test connector) under left dash to see if I am getting any info from the diff sensor. I have a good pedal, no fault lights and definitely no antilock.
Thanks
Thanks
Yes, the bulb is good and the light does come on when you first turn the key on. It stays on for a couple of seconds. I also did the black wire ground out from the computer thing and just got the ABS light with no codes. I was wondering if the sensor on the diff gear were to come off if the compuiter would know this. I wouldn't think it could while it is just sitting there as it is isolated from the system.
I am pretty sure I have no ABS. When I first leave the driveway they totally lock up wet or dry. I know what they should feel like as my gas powered 96 had them used in a couple of panic stops.
If I hooked a meter to that extra plug what should I see as I drive??
hotdram
Mar 23, 2005 07:45 PM
t-15 firefighter
17
Sep 30, 2004 05:41 PM
