ABS bypass
ABS bypass
Today I ventured underneath and I bypassed the ABS valve. I did it different so I wanted to share it with yall. First I took out the small line that goes from the valve to the rubber line to the axle, stored it away for later use. I then cut the main line feeding the valve with pipe cutters. I cut it about 4 inches from the valve toward the front of the truck so that I would leave myself enough slack to move it around. I then got the short line that goes to the rubber one that I stored and robbed the small fitting off of it. That fitting is the one that threads into the rubber line. I then took that fitting slid it onto the main line and then with a double flair kit flaired the end. All that was left was to connect the main line to the rubber one that goes to the axle. I bled the brakes and then proceeded to annoy the neighbors. Before all this my back brakes would lock up real easy, NOW I can lock up all four at my descrepency. The pedal isnt rock hard or anything but it is better. The best part about this is that it cost me NOTHING!!! Now I need to rid my truck of those annoying abs/brake lights.
I simply just cut the line going into it and put a fitting on it, flared it. Then cut the line coming out of it and put the fitting on and flared it also. Then I used a coupler to join them. Easy, took about 20 minutes.
fitzydog
21
10-11-2017 12:09 PM
sssmaly
07-13-2007 12:57 PM
mr T
02-24-2007 06:42 AM
