? about drilling for pyrometer
I am wondering if this is OK, I have the manifiold off to replace gaskets and install the 16cm housing. I don't have a pyrometer yet but want to go ahead and drill/tap the hole. Will the hole be 1/4 or 1/8 pipe. I will be using a di-pricol pyro to match my boost gauge.
Originally Posted by DODGE 92
my pyro was 1/4 pipe ithink
Worked out great.
Anyways, the size of the hole depends entirely on the kind of thermocouple or pyrometer probe that you buy. Most are 1/4 inch, but there are a good number of 1/2 inchers out there. (The one I bought from Autometer was a 1/2 inch.) There might even be a few metric ones floating around, I don't know.
Other than that, before you drill remember to take the turbo off to avoid shrapnel in the impellor, to stuff a oily rag into the manifold to avoid getting shrapnel in your valves and to use the high-temp anti-seize...
Went ahead and drilled and tapped the hole out for 1/8 pipe fitting. Went smoothly, no problems. Used the plug I took out of the head for the boost gauge to plug the hole, with never-sieze on the threads. Should have it back together the next day I'm off.
Originally Posted by Begle1
I assume that you have the thermocouple that you are going to put into the exhaust manifold? I wouldn't recommend drilling holes in your exhaust without having something to plug into it...
450r
21
09-26-2007 08:39 PM
wadem
10-03-2004 12:54 PM
Moose10
18
08-06-2004 12:39 AM
TinJim
04-28-2003 09:50 PM
