A518 to g360 Swap
Old Jan 2, 2011 | 01:07 PM
bulltamer's Avatar
A518 to g360 Swap
I have the getrag sittin in my shop with the flywheel, clutch, hydros. What is required to do the swap in a 2wd I'm gettin tired of the auto screwing up so I'm swapping it out
Old Jan 2, 2011 | 09:36 PM
Philip's Avatar
Your going to need a trans tunnel from a stick shift cab. A 4x4 auto or stick has the same floor tunnel as a 2Wd stick does.
I am not sure if the trans cross member is the same between a stick and auto.
Old Jan 2, 2011 | 11:39 PM
dodgenstein's Avatar
Club cab 2wd have the big tunnel.
Old Jan 4, 2011 | 12:01 AM
Philip's Avatar
Don't bet on that. I stripped a 92 D350 auto dually last year. It had the low floor in it. It was an Xcab also.
Old Jan 4, 2011 | 10:41 AM
12valvin's Avatar
Gotta have your cross member, make a mount in the firewall for your clutch master cylinder, mount up your pedals, wire your nuetral start switch from the auto harness, and wait for days till the hydraulics bleed the air out
Old Jan 4, 2011 | 10:43 AM
12valvin's Avatar
Oh and there will be driveshaft work. Its been awhile since I did mine on my last truck so there are probably some things im missing
Old Jan 4, 2011 | 04:16 PM
Subliminal's Avatar
My truck had the mounting hole with a rubber grommet in it when I did my swap. I just got rid of the neutral switch as it was all busted, and never had to bleed any air. The crossmember will probably work, too...although it isn't quite as beefy on the auto, and it makes the back sit slightly lower than it would with the 5 speed setup. Just FYI.
Old Jan 4, 2011 | 10:00 PM
RednekRangeR's Avatar
my auto and manual cross members where pretty much identical.
only difference was the way the transmissions mounted to the crossmember. donor was a late 1990 cab/chassis mine is a 1993 w250
Old Jan 5, 2011 | 09:41 PM
bulltamer's Avatar
I need a shifter boot where can I get one cuz the one out of the donor truck is trash ideas?
Subliminal
Nov 5, 2011 08:44 PM
DevilzTower
Nov 7, 2010 08:02 PM
DevilzTower
Jun 28, 2010 12:25 PM
93Fury
Feb 1, 2009 05:19 PM
jefe4x4
Aug 14, 2008 01:23 PM
