a518 cooler lines
Old Mar 18, 2014 | 02:07 PM
aicomp's Avatar
a518 cooler lines
Hi All,
Does anyone have a diagram of how the a518 cooler lines run? I have a truck, a "92 W250 , that the lines were cut when removed. Also, is there an in and out on the engine mounted and front mounted coolers?
Thanks,
Mike
Old Mar 18, 2014 | 03:07 PM
JD730's Avatar
I don't have a picture, but it comes out of the front of the trans goes across to the pass side, in the rear of the trans cooler on the side of the block, comes out the front, back across to the drivers side to the front cooler, then back too the rear port on the trans.
Old Mar 18, 2014 | 03:55 PM
dodgenstein's Avatar
If you have the dealer installed underbed cooler, it is plumbed between the front trans port and the heat exchanger on the right side of the engine.
Old Mar 18, 2014 | 04:11 PM
aicomp's Avatar
Thanks,
I don't have the rear cooler, but the info is great help and I will have it plumbed tomorrow. Can't wait to get it runnin.
Mike
Old Mar 19, 2014 | 09:31 PM
aicomp's Avatar
I got them all hooked up. The P.O. had cut all the lines when he removed the trans. Turned out that they matched up really close. I just picked up some compression fittings and joined them together. The new trans is hooked up and awaiting fluid.
Thanks to all for the replies.
Mike
Old Mar 21, 2014 | 07:26 PM
JD730's Avatar
Wow, some people are just savages.
Old Mar 21, 2014 | 10:01 PM
aicomp's Avatar
Pretty silly when all that had to be done was to disconnect two fittings. The truck came with all the cut lines . I would have done it in a little less barbaric manner.
oliverbutthead
1st Gen All Products
0
Feb 27, 2015 05:21 PM
MrKen
Feb 25, 2005 04:22 AM
hellotbone
Sep 1, 2003 08:46 PM
gofastman
Nov 23, 2002 06:49 AM
USMC64-70
13
Oct 23, 2002 06:58 PM
