93-w250 front leafs
93-w250 front leafs
Looks like the next step is front leaf springs since the originals are flat and maybe even cambered down a little. What I've found is Skyjackers with 11/2" lift from Summit for 340.00 for the pair and the bushings for 38.00. Any advise or recommendations before I order appreciated.
a 93 Will have 3/4" spring bolts, I think the skyjackers have 5/8. Just the matter of switching out a bushing.
Get the OD of the bushing though, Just went through this on the rear of my truck. I needed to replace my front of the rear spring bushing, and the PO of my truck had custom springs made with eyelets that used a bushing with an OD measurement of 2.5", factory 1st gen is 2.25" OD on the bushing with the 5/8 bolt down the center being used on the 89-91 trucks........
^^ I"m not sure about that
My 90 CTD used 1/2" bolts up front
The 92 (also a CTD) I striped the leaves from to to use in my 2wd to 4wd conversion were 5/8th bolts
FWIW, i will be order a set from these guys, the jackers are better than stock but still not great but these are supposed to be pure awesome.
http://www.customsuspension.com/stor...oducts_id=1742
Went ahead and ordered the Skyjackers #D-200-CS that has the 2" lift. Hope the front doesn't end up higher than the back. Thanks for the help, I'll update once I get them on the truck. I think I'm going to have more in this truck than the 07.
I put 2 inch lift springs on mine and needed to do a little clearance grinding on the cardan joint at the T-case to get full articulation of the joint with the front axle hanging. You'd never see that condition on the street but might off road. The length of the driveshaft was OK.
Got the Skyjackers in yesterday pretty basic install measured before 21" from top of hub to wheel well now 23"1/4 so did what it was supposed to. A little higher in the front but with the flatbed can't really tell, so far I'm happy, try to get pics.
Got the Firestone bags installed on the backend Sunday, quality setup easy install other than relocating a couple of supports on the flatbed. On a stock bed there would be nothing to it. With the new leafs in the front and the bags with 25 lbs air sits level with a load on it. Empty with a little air is pretty level. So far I'd rate the quality of the Skyjackers and the bags both as great quality.
MoPowa
Jun 18, 2010 07:44 AM
Bookshelf
Mar 16, 2008 06:40 PM
