93 Performance questions....
Old May 6, 2007 | 06:46 PM
miracle_boy9's Avatar
Hi,
I'm brand new here. I live in Canada and just purchased a 1993 Ram 250 Club Cab. The truck is all stock right now and i am wondering how to go about modifying it in stages. Where should I start? Which upgrades will give me the best bang for my nuck...any help is greatly appreciated!
Old May 6, 2007 | 07:19 PM
Short Box's Avatar
Welcome to the club!! I am also from Canada and fairly new to this site(about 5 weeks).If you are like me you will be spending hours on here reading and learning about your new truck, there is no shortage of info and shortly you will have all kind of suggestions. Also go to the top left corner, click on user cp and fill out your signature.
Old May 6, 2007 | 07:22 PM
DanMan's Avatar
Welcome! I too am relatively new.
As for mods, before even touching the pump or engine you need a set of gauges. EGT and boost are good starters, then a tach. There are 1 and 2 gauge A-pillar pods available for the 1st gens.
Old May 6, 2007 | 10:26 PM
93beater's Avatar
guages!!! trans, pyro, boost, then tweak the pump +2 full fuel, lower idle, max afc, -1 smoke screw, then grind your fuel pin or buy 1, and remove the washer, 3200 rpm spring, afc spring etc... good luck!
GotBoost?
Apr 13, 2006 09:33 AM
psychoseven
Mar 10, 2006 07:54 AM
Feukulor
Nov 19, 2005 05:23 PM
stone
Sep 28, 2004 07:28 AM
