93 headlights flashing and turning off
Old Mar 23, 2012 | 09:03 PM
Reapertura's Avatar
Just had my lights shutoff on the highway and start to flash, then they were off completely for about 15 seconds and then came back on. I guess ill look more at the wires in the am. but i saw no noticeable breaks on a quick inspection. also did this yesterday. any tips on specific place to look. I could not get them to shut off in the parking lot
Old Mar 23, 2012 | 09:07 PM
Onemoparnut's Avatar
Sounds like a bad head light switch to me.
Old Mar 23, 2012 | 09:13 PM
Reapertura's Avatar
where is that located?
Old Mar 23, 2012 | 09:45 PM
In the dash it is where you turn the lights on that is the head light switch.
Old Mar 23, 2012 | 10:18 PM
wheelieking71's Avatar
there is also a circuit breaker in the headlight circuit. but, i agree, sounds like the switch. if not, check the grounds under hood.
Old Mar 23, 2012 | 10:36 PM
Buddy Stewert's Avatar
Do you smell anything.
Have you been towing a trailer.
Old Mar 24, 2012 | 12:12 AM
Reapertura's Avatar
no smell, no trailer.
Old Mar 24, 2012 | 10:47 AM
jbawden's Avatar
Headlight switch is the most likely issue. I replaced a couple of switches in my 93 and then finally did the Jim Lane light harness mod and have never looked back....speaking of looking forward, the reliability of the lights is first and foremost, but they are 30% brighter now too.
Old Mar 26, 2012 | 12:48 AM
NE frmhnd's Avatar
Light switch. I put Sylvania Extra-vision lights on mine and had to put relays in it. I only did one light, but have plans for re-doing the entire light system with relays. Might even put a momentary switch in to be able to blink my lights.
Old Mar 26, 2012 | 03:22 AM
Reapertura's Avatar
if i do the jim lane fix will i still have to replace the switch
Old Apr 1, 2012 | 08:58 AM
NE frmhnd's Avatar
Possibly now, possibly later, you won't know til you try it. If they are staying on a while before they start kicking out I would guess it may last a while longer.
Old Apr 1, 2012 | 06:56 PM
Midnite's Avatar
At the very least one of the contacts on the switch will be a little burnt--you need to pull it out and clean off the crud.
Old Apr 1, 2012 | 07:00 PM
I would change the switch and do the relays that way you know it will work properly.
ImprezdGurl
Jan 2, 2009 06:30 AM
Townsend600
Dec 1, 2007 03:21 PM
goin
Aug 7, 2003 06:33 AM
Hummin Cummins
24
Jul 17, 2003 12:50 AM
