92 underhood wiring diagram needed
Old Jun 18, 2007 | 08:04 AM
imfixinmopars's Avatar
i looking for a downloadable diagram of the wiring fo my 92 cummins truck.my pcm died and im trying to bypass it to "normal".i bypassed the alt reg[easy] and manually controlled grids, im wanting to get the a/c working manually.i assume the pcm controls the a/c because the cluth engages in and out w/ the ck eng lite.i was wondering if the pcm controls the cycle of a/c? i looking for a manual,but my buddie that has one,isnt my bud any more. lol.untill then does anyone have any pic ect of the 92?thanks,great site!!!!
Old Jun 18, 2007 | 05:55 PM
Check the crank sensor wiring.
The PCM controls the A/C clutch.
Old Jun 19, 2007 | 11:40 PM
jrmcleod78's Avatar
Sent you a private message. I have the wiring diagram, can't upload it for some reason
Old Jun 20, 2007 | 04:14 PM
Winr's Avatar
There is a relay on the Drivers side fender. there should be a blue w/black tracer wire, blue, and blue w/orange tracer. Short the blue w/orange tracer wire to ground and the compressor should kick in.
The signal for the PCM to turn the A/C system comes from the heater control, grounding the other side of the Blue/orange wire.
So, all that being said. Look at the firewall bulk head conector, in the lower left corner of the connector the BL/org wire should pass thru there, pull that wire from the harness ( bulkhead to PCM) connect the PCM end to the same location on the relay. that should do it. Clear as mud????
PM me if you have further Q's
Bill
4RnrRick
Apr 17, 2019 11:01 AM
addicted
Mar 19, 2017 04:57 PM
GCSS
Jul 19, 2012 06:35 PM
rjmelehan
Jun 6, 2011 05:14 PM
silverbullet02
Dec 20, 2006 03:48 PM
