92 auto aftermarket options???????
who makes upgrade kits for the 92 auto with od and or who can i get a complete trans mabey even lock up??? please i really need some help here. i plan to be in the 3-375 range.
Dave Goerend is the man you want to talk to.
http://www.goerend.com/
It would probably be better to give heim a call, but the website shows a couple things for the A518. He'll set you up.
Dave Goerend for the win.
www.goerend.com (563) 778-2719
375$ will get you a shiftkit and maybe a stock rebuild kit if you do the work yourself. Thats kinda a low budget for a tranny
to get a lockup you need a tranny and starter/adapter plate out of a 94-95 second Generation cummins truck and those are pretty weak trannies unless you build them up.
[QUOTE=Crossy's son;2339929]375$ will get you a shiftkit and maybe a stock rebuild kit if you do the work yourself. Thats kinda a low budget for a tranny[QUOTE]
I'm fairly positive he meant he planned on being around 375rwhp. I'm sure he knows tranny work will be more than $375.
Yea Thats Hp Not $$$$ But $$$ Would Be Cool To.wow Thanks For All The Info I Have Tried Cummins Fourm And Tdr For About A Month I Got Absolutely No Results Thanks And Keep Em Comming
for you a lock up trans you will need to swap in a 47rh. A few have done it, not too much work but a little more money. If i decide to keep the auto in my truck this is the route i am going.
Not true, the A518 can be converted to lockup with a few parts. Of course you need a new adapter, starter and a lockup converter. To change the trans over you need a lockup input shaft, a lockup reaction support or whole front pump and a valve body to control the mess.
[QUOTE='91 1st Gen;2339999][QUOTE=Crossy's son;2339929]375$ will get you a shiftkit and maybe a stock rebuild kit if you do the work yourself. Thats kinda a low budget for a tranny
Good point! I didnt think of it that way, I just made a fool outta myslef
RobG
Jan 16, 2015 08:00 PM
FishBio31
Jul 8, 2010 10:07 PM
LanceK
Nov 21, 2007 04:27 PM
I PASS GAS
Mar 16, 2006 07:59 AM
