92 12v cummims slightly bent pushrods??
Old Aug 25, 2018 | 08:41 PM
Jared Harper's Avatar
I recently did the killer dowel pin fix everything went smooth started the truck up ran it a little and come to find out all 12 of my pushrods bent and cracked very slightly near the top. Could over torquing the head bolt going through the rocker support be the cause? These are stock head bolts and the truck has 180k. Also the other head bolts in the cwnter of the head werent fully torqued to 120 which i believe is the correct spec. Anyone have any ideas or had this happen to them ? Note: I double checked that all pushrods were seated into the lifters properly.
Old Aug 27, 2018 | 02:50 PM
BigIron70's Avatar
Cummins Guru
Did you remove cylinder head? Did you set valve clearance to spec?
mitch125
Oct 22, 2012 03:56 PM
powerstrokin03
Apr 28, 2007 03:26 AM
first4age
Jul 20, 2006 03:43 AM
Crimedog
Oct 17, 2005 04:23 PM
Bradtothebone
Jan 6, 2005 12:57 AM
