'91 vs. '92
'91 vs. '92
I need yalls help. I currently own a 1992 CTD with approx. 360K miles on it. This truck needs a paint job, it leaks transmission fluid pretty bad, needs a new master brake cylinder, but it has a good cold running AC. Ok, now my friend has a 1991 CTD with 188K miles on it and it has a newer flawless paint job that is about 8 years old it doesnt leak at all and the brakes are good, BUT it does not have a working AC. So my question is should I sell my truck and get this one from my friend since his is for sale or is the 1992 a better truck?? I guess my question is whether one truck is better than the other or if one is known to be a better truck than the other or if they are simply the same and a wash. I need you guys to tell me what you think and what you would do. THANKS!!
If it is a '91.5 then it will be intercooled and have overdrive. If it just a '91, then it will have the 3spd auto and won't be intercooled.
There aren't really any differences between a '91.5 and a '92.
Yea, buy the 91. lower miles and it doesnt need as much $$$$ in work. the 92 sounds like the trans needs a gasket (work). and it has alot of miles. things are going to start to wear.
