91.5 4x4 rear axl spline count
Old Dec 28, 2008 | 02:24 PM
Fergavs's Avatar
I need to order a locker for my 91.5 D250 4x4. It should be a Dana 70 I'm sure but did Dodge use a std spline count on all our trucks. I need to know my spline count. I quess I can go pull a shaft... but if they are all the same. Anybody know?
Old Dec 28, 2008 | 05:03 PM
Pull a shaft, it varies.
Old Dec 28, 2008 | 10:25 PM
CTDreul's Avatar
they are 32 spline
Old Dec 29, 2008 | 02:09 AM
cell's Avatar
Mine is 32
Old Dec 29, 2008 | 10:31 AM
Flake's Avatar
I've got a SRW 70 from a 90 or 91 sitting in the garage and it has 35 splines, only way to be sure is pull a shaft.
Old Dec 29, 2008 | 12:00 PM
bgilbert's Avatar
As long as this wasn't switched along the line, probly not in just about all cases, an easy way to tell without pulling a shaft is if the shaft is retained by bolts, it's a 32 spline shaft. If it's retained by studs it's a 35 spline shaft.
Old Dec 29, 2008 | 12:39 PM
PapeCAT's Avatar
My D71 3.07 is retained by Studs with Nuts on the Outside.
Old Dec 29, 2008 | 02:12 PM
Fergavs's Avatar
I pulled an axle shaft and checked. Mine is a bolt on flange (no studs) and it was 32 spline. So looks to be pretty standard. Thanks for the input guys.
ridofpwrstroke
Mar 20, 2005 08:10 AM
clc900
Nov 18, 2004 07:46 PM
clc900
Jul 16, 2004 07:53 AM
Alec
Jan 30, 2004 08:53 AM
