9 speed in a dodge
Old Aug 31, 2007 | 10:20 PM
  #46
ez_lle71's Avatar
Clutch-less shifting does not work very well in most synchronized transmissions.
The synchronizers will spin the gear, such that it will "grind", instead of sliding in gear.
Some transmissions are worse for this than others.
No offense bearkiller, but my dad's 95' ctd with a NV4500 shifts easier, as he says, without the clutch. My NV5600 is getting smoother and my getrag i try to use the clutch more because it is not as smooth as the New Venture transmissions. A 9 speed would be cool but having to clutchless or double clutch it would get old on the street for a daily driven truck.
Here is my thinking, A 3 speed brownie with Lo, direct, and overdrive would be cool because u would have the option of splitting each gear in the main tranny 3 times, or you could leave the brownie in direct and have your original gears and then could split 5th to have a double over. Maybe I'm in a dream world! haha Later
ez
Old Sep 2, 2007 | 01:45 AM
  #47
Munchies's Avatar
Originally Posted by andyr354
You can put in lower than 3.07 gears with a spacer ring.. but they don't recommend it. It makes them much weaker.
Or you can buy a 'thick' ring gear. or you can buy a 4.10 and numericaly higher carrier.
1stgenatheart
Oct 19, 2009 06:33 AM
faster_than_ford
33
Mar 5, 2004 07:24 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
