89 intercooler
Old Jan 22, 2005 | 08:26 PM
rockjeep73's Avatar
89 intercooler
I have an 89 cummins without an intercooler, should i get one? Does anybody else get them? Where can i get one? Do i need one?
Old Jan 22, 2005 | 08:33 PM
That depends on what you're planning to use the truck for. If you're going to be towing heavy with a turned up pump and big injectors, you ought to get one. It will keep your EGT down so you can use more of the power that your truck is capable of making. If this is just a daily driver/beater/play truck, it's not really needed. Bank$ sells just the intercooler kit, you don't have to get their whole package. Cost is close to $1,000.
Old Jan 24, 2005 | 02:26 PM
rockjeep73's Avatar
Can I get one off a newer dodge?
Old Jan 24, 2005 | 02:55 PM
92DIESEL's Avatar
I believe you can retro fit a '92 or '93with some mods to the radiator support.
If I'm wrong the guys with more experiance will let you and I know.
Just going off what I've seen in past postings.
Old Jan 24, 2005 | 03:01 PM
Yes, but trying to find a good used 1st gen intercooler is pretty difficult. If you luck into one, go for it. If you can get the core support out of the donor, do that, it will make things easier.
Old Jan 24, 2005 | 03:57 PM
TLRMAN's Avatar
How about a water/meth injection system. You can set it to come on at any given boost level.
THis should have the same effect as the intercooler...
92smokin blacky
Jan 14, 2010 09:23 AM
6Stix
Feb 13, 2009 08:32 AM
mullishacrew
Oct 30, 2008 09:29 PM
Marine
Feb 7, 2003 06:32 PM
csaverline
Oct 23, 2002 04:55 PM
