Are 727, 518, and Getrag engine adapter plates the same?
Old Jan 20, 2009 | 03:47 AM
Bookshelf's Avatar
Are the engine adapter plates(flywheel housings) on 727, 518, and Getrag equipped trucks all the same? I'm sure this has been answered before but I couldn't find it. Thanks
Old Jan 20, 2009 | 07:57 AM
apwatson50's Avatar
Yes
needmorewords
Old Jan 20, 2009 | 08:35 AM
Free89W350's Avatar
Yes..................................
Old Jan 20, 2009 | 08:47 AM
pwrtripls1's Avatar
Since that was easy, where do you find an adapter for a 4L80E trans behind one? They have great gear ratios for a diesel, can hold 1,200 whp/wtq all day when built, and cost half as much as a built 47re or rh.
Old Jan 20, 2009 | 09:38 AM
Trebor's Avatar
True until you factor in a used adapter for around $400 or new at over $1,000; then you will still need the custom aftermarket controller costing in a starting average range of $900 and up. Kinda kills the bargain part really quickly.
Old Jan 20, 2009 | 11:46 AM
pwrtripls1's Avatar
Just need the plate and flywheel. No controller needed if you want to go with a manual valve body and TC lock up switch. I found some of the 4bt applications had 4L80E's behind them, so if I can get ahold of one of those I'd have everything I need. Then send the trany to FLT and have them build it with a manual VB and a billet convertor.
Old Jan 20, 2009 | 12:45 PM
Free89W350's Avatar
I didn't see the Getrag in there at first. I am not positive if they are the same as the auto trucks. I believe they might be different.
Old Jan 20, 2009 | 01:08 PM
Bookshelf's Avatar
Yes, getrag compatibility is key, since I'm looking for one for that purpose. Anyone who's done an auto to manual swap care to chime in? I don't want to buy something that's not going to work.
Old Jan 20, 2009 | 02:03 PM
Alwaysworking's Avatar
alwaysonDTR
they are the same
Fergavs
Feb 14, 2011 03:12 PM
J Lent
60
Nov 3, 2009 09:14 PM
archer2
Feb 1, 2008 02:28 PM
copasspupil
Apr 27, 2007 03:25 PM
PeytonMaterne
Aug 16, 2006 04:37 PM
