47rh or Getrag?
Old Sep 9, 2010 | 07:04 AM
Subliminal's Avatar
Originally Posted by artieb
If I go the 5-sp Getrag route from my A518 Do I need to adjust my driveshaft lengths?
Yes.
Old Sep 9, 2010 | 09:28 AM
BearKiller's Avatar
If I am reading all this correctly, the Getrag you have is a 2WD, right ??
Were it myself, I would seek out or fabricate the necessary components to DIVORCE-MOUNT that NP-205.
Done right and braced properly, there are a host of advantages to having the transfer-case divorce-mounted.
The only reason that the auto-makers started using the "married" transfer-case is cheaper and quicker to install on the assembly line.
Old Sep 9, 2010 | 11:30 AM
artieb's Avatar
I would consider that, what transfere case would I use? I remember the old Fords, and driveline issues. Does anyone have more info on a divorse? T-case, I wouldn't mind getting rid of my midship carrier, Let me know, Artie
Old Sep 9, 2010 | 03:11 PM
BearKiller's Avatar
A NP-205.
The one you have should be adaptable to divorce-mount.
Old Sep 10, 2010 | 01:18 PM
artieb's Avatar
SOOOO.... Summary is this. If I wanted anything else in my Dodge, other than a A518 ( or use A518 hybrid with the 47rh) 23 spline T-case.
I need to have a 29 spline transferecase. NV4500, NV5600, Getrag 360 or complete 47rh? Does the divorced NP205 have more driveline vibrations? And the advantages would only be, that I could do anything trans wise, in front of it, then adjust my intermediate driveshaft?
Has any of the rockcrawler crowd devised a companion flange to connect trans output to T-case input without a driveshaft?
Old Sep 10, 2010 | 06:25 PM
BearKiller's Avatar
A properly mounted divorced unit will have no more vibrations than a carrier-bearing.
Auxilliary units were divorce-mounted in big trucks for years.
Flanged U-joint yokes are available for the 205 and could easily be fabricated for a Getrag.
Most of the drive-line vibrations that divorce-mounted transfer-cases got the blame for were actually caused by the front drive-shaft and the fact that most of the trucks of that time had no provision for un-locking the hubs.
Old Sep 11, 2010 | 10:45 AM
artieb's Avatar
The divorced thing is what I'm working on. Looking for pros and cons?
Easy way or the hard way, and it's never the easy way.
Old Sep 11, 2010 | 01:30 PM
Mark Nixon's Avatar
There are so many different ways to do transfer case set-ups.
One of which I gave you over the phone, artie.
Mark.
JBradley500
Jul 31, 2012 06:16 PM
77machomopar
Feb 13, 2009 03:05 PM
Fergavs
May 24, 2007 02:00 PM
ramguy
Jun 30, 2003 02:01 PM
BoldtsWagon
Jan 24, 2003 11:05 PM
