Is there a Getrag 4x4 to 47rh 4x4 swap write-up?
Old Jul 31, 2012 | 05:41 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
I may have a chance to get a core, and i have a hookup with parts and what-not. I think ill probably buy and build one just because i have the opportunity right now to do it for cheap. This thread will just give me an idea of what it may/will take to do the swap.
I would love to see a writeup on this but i cant find one?
Maybe we can start a list of things that need to be done/changes? Here's a quick list i tried to come up with off the top of my head. Any input would be appreciated.
T-case
Drive shaft lengths
adapter plate
starter
flexplate
cooler
lines
tv/kickdown cable
switches for od and lockup
Old Jul 31, 2012 | 06:16 PM
user name's Avatar
The OD switch is wired in the dash harness just needs hooked up and the underdash wiring run. You could run that wire and the lockup wire then use a 94-95 PCM. You will also need TPS and that wiring if you want it to work that way.
jstone44720
Oct 1, 2012 08:10 AM
Subliminal
Dec 13, 2010 05:58 PM
77machomopar
Feb 13, 2009 03:05 PM
Deadbunny
Jan 7, 2009 04:37 AM
Fergavs
May 24, 2007 02:00 PM
