47 re conversion
Old Sep 3, 2010 | 08:47 AM
oldblue93's Avatar
47 re conversion
what will it take on my 93 dodge clubcab cummins to convert to a 47 re out of a 2000 dodge with a v10 i know i have to change conveter valve body, what do i have to change on my truck to make it work or is there a better trans with lock up that will work better
thanks joel
Old Sep 3, 2010 | 09:19 AM
Onemoparnut's Avatar
The 47RH will be better the RE is electronic and needs a computer to control it the RH has a hydraulic governor that controls it.
Old Sep 3, 2010 | 09:37 AM
92smokin blacky's Avatar
trans adapter plate off a 2nd gen, 2nd gen flexplate, and 2nd gen starter. I'm goin to get a 47rh today.
Old Sep 3, 2010 | 01:49 PM
samiam4's Avatar
V10 going to have different govener weights in the tailshaft housing...
Diesel 47RH which is a lockup 518(618) trans.
Drain the torque converter into a clean pan and then put the trans on end. R&R the pan before purchase to make sure it's not filled with metal flakes.
I didn't and got burnt. The junkyard found a replacement which has been rebuilt in the last 2 years. So all turned out well.
Make sure the pigtail on the transmission comes with it. The dipstick tube would be good, but almost always gone. Flexiplate off the engine .. 1st gens are weaker.
Going to try and put mine in this weekend!!!
M
Old Sep 7, 2010 | 09:50 AM
JD730's Avatar
thanks joel
It would be easier to take the front section of the trans and use your overdrive section to make a 47RH, unless you're going to run a manual valvebody. To make a RE into a RH you have to you have to change the OD piston retainer to the old style or replace with an aftermarket one so the govenor tubes can connect and feed to the valve body. The only thing you'll need is the engine adaptor plate, starter, flexplate, and a 47RH valvebody with connector.
47RE's don't have govenor weights so, the V10 and diesel 47RE's are basically the same. A true statement when talking about a 47RH.
xzlram
Nov 10, 2002 08:28 PM
Teddy
Nov 2, 2002 01:56 AM
CMN_NOT_STROKN
Oct 29, 2002 09:53 PM
ace01
Oct 21, 2002 04:59 PM
Superduty12v
22
Oct 11, 2002 07:42 PM
