3200 spring install......"foot"?
Old Aug 17, 2008 | 10:04 AM
jj3500's Avatar
Reading the sticky....refers to the "foot" and that is it ground down in some applications. What is the benefit of this? Performance? If so, to grind it, what do you guys do to get in that tight spot(hand held grinder?) Or do you remove it out of it housing?
going to do this today, sunday. can't wait.
thanks
Old Aug 17, 2008 | 11:49 AM
Alwaysworking's Avatar
alwaysonDTR
the foot grind is only for play trucks, i would not d it on any truck that you tow with.
but if thats what your going to do, you could use a file, die grinder or remove it and use a bench grinder, if you leave it in a grind it, make sure you clean it well
Old Aug 17, 2008 | 12:09 PM
CaptainChrysler's Avatar
You might want to just take it out and try it. That way if it's way too smokey, you can just put it back in.
Your right foot will be the only AFC with it removed.
Old Aug 17, 2008 | 12:27 PM
jj3500's Avatar
Oh...its just to make smoke...is that the jist of it?
Yes, this is a work truck. I plow and dump with it.
thanks
Old Aug 17, 2008 | 12:52 PM
alwaysonDTR
basicly yes smoke untill the turbo lights, if you want to see what it will look close too pull the afc spring and then drive it
Old Aug 17, 2008 | 01:31 PM
thanks
No, it lets the governor lever travel further which means more fuel/power. An unfortunate side effect is smoke at low boost.
I would not do it to your truck. As was said, it's a play truck kind of mod.
hounddogks76
Aug 31, 2012 09:22 AM
92smokin blacky
Oct 3, 2010 07:21 AM
BurrisWill
Jan 25, 2009 08:23 PM
PeytonMaterne
Aug 11, 2008 05:25 PM
aaronedwards82
Aug 26, 2006 04:42 AM
