3200 spring
Old Sep 7, 2005 | 12:55 PM
ihpower's Avatar
3200 spring
are there any down sides to the 3200 spring. making the motor spin faster kind of makes me nervous. but i know a lot of people do it. but i guess one of our tractors will 3200 all day long i have done it. so i guess i just want to know if there are any flaws the the 3200 spring.
Old Sep 7, 2005 | 01:17 PM
csramsey640's Avatar
nope no probs. When you goto a 4k spring, then youll need some additional heavier valve springs, but 3200k is fine.
mhuppertz's Avatar
3200 Spring
According to Cummins the redline is at least 1,000 RPM's above 3,200RPM, and I suspect it's more like 5,000 RPM, so you are not going to hurt the engine at all, and once you have it on the smile won't leave your face for quite some time!
Old Sep 7, 2005 | 01:40 PM
ihpower's Avatar
ok so it will not hurt the motor . but the problem for me is putting the spring in.
Old Sep 7, 2005 | 02:03 PM
mainer's Avatar
dont the springs blow the tip off of the shut down selonid? also where does one come by one of these springs?
Coop
Old Sep 7, 2005 | 02:08 PM
ihpower's Avatar
you can get them from cummins
Old Sep 7, 2005 | 02:15 PM
or a bosch fuel injection dealer
Old Sep 7, 2005 | 04:32 PM
I think that's more of a "turned the pump up a lot" problem. If high RPM was the culprit old VW's would eat those things like candy.
If you can find a pump shop near you, that is the cheapest place to get the spring. PDR sells them too.
The 3200 RPM spring really transforms the truck. It puts you much more in control of the fuel. It's the difference between driving with your foot and driving with your big toe.
Old Sep 7, 2005 | 05:06 PM
ihpower's Avatar
ok so its final i am giong to do it now i just need help getting it done. ill have to start asking my friends some are good at that stuff. two are diesel mechanics
Old Sep 7, 2005 | 07:07 PM
Boatnik's Avatar
I bought mine last week from Industrial Diesel in Norfolk VA for $ 12.74 plus sales tax. The Bosche part number is 1-464-650-366. This is for the VE pump. Their phone number is 757-857-5391. Ask for Jay. It's a real kick in the pants
Old Sep 7, 2005 | 07:44 PM
mhuppertz's Avatar
Tigger
I can't wait for the first time you jam on it with the new spring and the pump advanced!!!!! Keep us posted!
Old Sep 7, 2005 | 10:43 PM
timb's Avatar
And just in case, go ahead and buy the pull cable.
Old Sep 8, 2005 | 10:48 AM
GreatWhite91's Avatar
So as long as you "take it easy" there is no danger of harming the engine in any way?
Is the installation difficult? (I'm not exactly sure where the spring is but I have a pretty good idea.)
Old Sep 8, 2005 | 04:54 PM
Yeah, you don't HAVE to use the extra RPM. Mine stays below 2500 most of the time, maybe a couple times a week I'll run 'er up to 3k. The stock valvesprings are OK to 32-3400. If you have an old non-intercooled automatic and you want to use the extra RPM on the highway, the HD valvesprings would be a good idea.
It's not so much difficult as it is nerve-wracking and time consuming. You really ought to have an extra set of hands for the actual R&R of the governor spring, but most of it is OK by yourself. Expect it to take a couple hours at least.
Old Sep 8, 2005 | 05:17 PM
ihpower's Avatar
if i do tear into it should i grind the afc lever? i think my dad could help he was a diesel mechanic for 20 years. but he dosnt like what i do to my truck
