3.07 W/Detroit Locker?
Ok, I know this one has been beat to death, but I still can't seem to find a clear answer. Detroit says they make a locker that will work with the 3.07's weird pinion offset, but I still want to confirm that it is a regular Dana 70, and not a Dana 70HD, and that it also has 35 spline axles...
I also heard an easy way to tell 70 vs 70HD was that the HD versions had 4-inch axle tubes versus 3.5 inch...anyone else know if this is true? I always heard that the 3.07s were 70HD's, but now all signs are pointing to them being regular 70s with 35 spline shafts and the weird pinion offset.
thanks guys
Jason
thanks guys
Jason
I believe they may actually be 70u's. If not, just a standard 70. No HD's were used in 1st gens, although, some some claim to have seen a couple with them but anybody can swap axles
. Do you have the BOM number from the data tag or axle tube handy?
3:07/3:54/4:10 uses the same carrier assy. The difference is the axle housing.
Just make sure of your spline count before you buy. Most 3:07's used 35 spline axles.
On a fast glance the eastest way to tell a 71 rear axle. Look at the pic below. That rasied area at the 2:00 position outside of the cover footprint. 70's do not have that. Just the 71 axle.
DTS doesn't need that tag. There is a alpha numeric data imprinted on the ring gear.
Were the RG says DANA on it's edge, there is a letter followed by 5-7 digits. With that, and the number of splines on the axles, supposedly they can order what you need...
That's what they wanted when I called for parts for my Diff.
The rule of thumb is, if it has studded in axles it's a 35 spline, if it has bolt in axles it has 32 spline.
all 3 91 non i/c trucks we had all had the bolt in axles, but the 89 rear i have has studded in axles and the hub looks alot different than the 91-93 rears
nfsommer
27
Mar 16, 2007 03:35 PM
canucktrucks
Nov 18, 2004 07:08 AM
. No data tag attached to the cover?
