2 batteries. Isolator? solenoid? switch?
Old Apr 5, 2012 | 11:53 AM
  #46
simplysmn's Avatar
For a battery box if you have anyone around your area that has any military vehicles look for the Dodge 880 series they have a very nice wide box that fit's in the stock location the military truck's come with a very wide battery and most also have 24 volt system's so they had a battery box on both sides of the frontend
Old Apr 5, 2012 | 02:41 PM
  #47
j_martin's Avatar
I use a 70 amp relay to the Deep cycle battery. Relay is driven by logic when ignition is on and starter is not engaged. Ignition AND Auxiliary works.
Ignition + goes to one side of the 70 amp relay coil. The other side is grounded by a pilot relay driven by the switched auxiliary.
Then it's a no brainer. When it's running, the Deep cycle is charging. When it's not, even if the key is in the auxiliary position, it is isolated.
dodgediesel
Apr 15, 2010 09:00 PM
utvaquero
Nov 23, 2009 09:33 AM
rharveysr
13
Oct 15, 2003 06:47 PM
apc
Feb 18, 2003 06:45 PM
