1st Gen & 2nd Gen Intercooler Specs
Was going thru some old files and found the dimensions for the 1st gen intercooler and a 2nd gen intercooler from 94-02.
Here are the dimensions for the intercooler out of a 93 model. This may help if you plan to build your own.
Part No: 52004274
Weight: 20 lbs
Tubes: 18
Fins per Inch: 12
Width: 37"
Height: 12 3/4"
Core Thickness: 1 5/8"
Inlet ID: 2 1/4"
Inlet OD: 2 5/8"
Inlet/Outlet Center to Center: 34 5/8"
Inlet Vertical Center: 6 3/8"
Inlet Length (from core): 4 1/2"
Dimensions for Intercooler out of 94-02 CTD:
Core size 36"x16 1/2" x 2 1/4" Thick.
Lower mounting insulators center to center, 39 1/2"
Inlet to Outlet center to center, 41 3/4"
Upper mounting eyelets center to center, 45 1/2"
Inlet & Outlet OD. 3 5/8", ID. 3 1/4"
Part No: 52004274
Weight: 20 lbs
Tubes: 18
Fins per Inch: 12
Width: 37"
Height: 12 3/4"
Inlet ID: 2 1/4"
Inlet OD: 2 5/8"
Good post Monty. I have been contemplating my own core support mods and reinforcement for when I build my bumper. Want to make room for an I.C. and other coolers. Thanks again,
Don
Don
pulltilbroke
Apr 10, 2009 02:08 PM
