1998 dodge 2400 rims on my 93 first gen?
Old Sep 8, 2014 | 10:37 AM
ridlangus123's Avatar
10 Year Member
Hi guys, im looking at a set of after market wheels and tires a guy had on a 98 2500 dodge, just curious if there going to bolt right on or if will need a spacer and or different studs? Thanks in advance!
Old Sep 8, 2014 | 11:58 AM
BearKiller's Avatar
I am uncertain which year Dodge switched from lug-centric conical-seat wheels to hub-centric flat-faced wheels.
If these wheels have conical lug-nut seats, then yes, the bolt-pattern should fit and the nuts should work --- PROVIDING there is not any negative offset that makes the rim contact something, usually the caliper or tie-rod.
If the wheels in question are pot-metal, commonly called aluminum, then I would not have them as a gift --- but that's just me.
Old Sep 8, 2014 | 01:49 PM
rrgrassi's Avatar
You can always test fit one on the front and then the rear to check clearance.
Old Sep 9, 2014 | 07:54 AM
mknittle's Avatar
The only way to know for sure.
Aftermarket wheels may be different offset than the stockers.
Old Sep 9, 2014 | 07:19 PM
And being "pot metal" aka "Aluminum" the rims will be thicker in stepped areas for strength. So there maybe, as suggested, clearance issues with the calipers and other front end components.
joe189man
Sep 10, 2008 09:28 AM
JDGPULLER
Dec 10, 2006 05:25 PM
honda_guy4
35
Jan 24, 2006 12:33 PM
Valv
Mar 24, 2005 06:55 PM
