1993 ecm bypass
1993 ecm bypass
The PO of my 1993 w250 4x4, automatic, air, bypassed the ecm. I'd like to return it to stock. From what I can see, ac still works, external voltage regulator, and the manifold heaters and OD are wired to switches on the dash. Im assuming that either the ecm went south or the crank position sensor and Im sure Ill have to fix that problem after the wiring is corrected, so does anybody have a wiring diagram?? Or any advice?? Thanks
KWKING
Feb 14, 2009 11:54 AM
Ohio Joe
Jul 12, 2004 12:13 PM
