1993 Dodge Questions
Old Mar 27, 2003 | 09:40 AM
PurdellMGP's Avatar
Re:1993 Dodge Questions
Thanks for the FAQ - I looked and read...<br>Guess it makes for a weekend project! <br>Now by leaving this unfixed I assume that is when you get water leaking into the drivers side area by the e-brake pedal?<br>I am gonna have to look at my truck when I get home. First I have heard of this problem - Appreciate all the info guys!<br><br>If it worked...I have attached a pic. of my 88 1/2 ton LE package, 2&quot; lift 318 (yes...I know not a diesel ) But I am working on it. If all goes well I should hopefully be driving it home in a couple weeks!
Old Mar 29, 2003 | 12:10 PM
Sootblower's Avatar
Just to let you know I had that cowl crack on passenger side and realized it was a lot of labour to fix. I decided on a temporary repair to cut the noise that drove me crazy. Open passenger door wide . Look at closely with small mirror on telescoping handle to see where it is worst. Wipe clean and then apply silicone seal all over cowel corner and let dry. Temporary repair was in 1996 and has been good enough I never touched it since. Silicone is waterproof and it seemed to stop the edges of the crack from grinding against each other and causing racket.
Old Apr 1, 2003 | 11:48 PM
Paws's Avatar
Do these &quot;cowl cracks&quot; cause water leaks in the cab?
Old Apr 2, 2003 | 09:41 AM
dodgeman01's Avatar
took a look to day and yep I have the crack. actually there are two on the Pass side of my truck. :'( I guess I found out what was causeing that sound.<br>DM01
jcb
Jan 31, 2006 08:40 AM
saltydog
Jan 26, 2006 05:39 PM
saltydog
Jan 24, 2006 01:45 PM
cybermallinc
Oct 9, 2003 07:20 PM
