1992 Turbo Transimission Problems
Old Dec 7, 2012 | 08:27 AM
Lawrence Placek's Avatar
I have a 1992 250 2 wheel drive automatic with cumming Turbo with 170,000 miles. When cold transmission is not shifting into over drive or going back and forth. When it warms up it seems fine. Also speedometer is reading very slow when cold but seems to go up after warming. Transmission oil is clean, no leaks, no smell, no slipping. I've bought this used and not real familiar. Any suggestions?
Old Dec 7, 2012 | 08:53 AM
sooty's Avatar
check trans speedo transducer, might be coming loose, or loose electric connection
Old Dec 7, 2012 | 09:24 AM
delsilver's Avatar
There is a temp switch that prevents OD from engaging till up to operating temp.
Del
Old Dec 7, 2012 | 09:26 AM
Hmmmm? That really seems like whats it's doing? Is that inside the overdrive or transmission?
Old Dec 7, 2012 | 10:26 AM
Bg enemy's Avatar
Should be on the cooler line just in front of the trans
Old Dec 7, 2012 | 11:55 AM
simplysmn's Avatar
Also check the fluid in Netural not park .
Old Dec 7, 2012 | 04:05 PM
JD730's Avatar
That is the switch that kicks overdrive out if the trans oil temp is over two hundred something degrees F.
One of the parameters is the coolant temp needs to be approximately 60F.
Old Dec 7, 2012 | 04:33 PM
dodgenstein's Avatar
Low temp OD cutout switch is in the side of the head just below the air inlet elbow.
Old Dec 7, 2012 | 08:23 PM
Bg enemy's Avatar
K thanks for clearing that up why would they put it their tranny heats up faster than the motor in cold weather it does in my new Chevy 1 ton and it has a supercharged gas motor
Old Dec 9, 2012 | 01:46 PM
NE frmhnd's Avatar
The transmission dumps most of its heat through the engine coolant.
Old Dec 9, 2012 | 03:58 PM
1972RedNeck's Avatar
Maybe it has something to do with the cumming motor.
pmtg
Apr 29, 2008 01:41 PM
Chuck
Oct 21, 2006 05:54 PM
jcb
Aug 22, 2006 10:30 PM
old dog
Mar 2, 2006 02:45 PM
drecu
Feb 23, 2004 07:40 PM
