1992 one ton
Old Aug 21, 2023 | 01:27 PM
willy wagon's Avatar
1992 one ton
what do you guys recomend for injectors? i belive i have pd 90,s or something like that done a long time ago. belive they were 40 hp injectors. must be something more efficient and maybe even drop EGT s a little by now?
Old Aug 23, 2023 | 08:52 AM
u2slow's Avatar
I went with stock replacement (9mm tips) for the pricepoint (rockauto). They fuel more than enough for me until I get a bigger turbo and/or an intercooler happening.
I believe 'marine 370' tips can fuel a bit more, and perhaps a little less smokey. My gut says they will be hot too.
Old Aug 23, 2023 | 01:03 PM
well i hope to put in 94 or newer rad and intercooler this winter, already has 4 inch ex, plus may do some more mods but as i say put in more efficient injectors if possible.
Old Aug 24, 2023 | 09:12 AM
u2slow's Avatar
5 or 6 hole injectors should burn a little cleaner. The marine 370's are 5. Stock non-IC is 4. Stock IC is 6.
Most of the efficiency gains with the Cummins B series is raising the injection pressure, but your VE pump can't compete with a p-pump, vp44, or cp3 for that.
Old Aug 24, 2023 | 10:42 AM
Contact Eric at The Hungry Diesel...I've heard good things about him and after talking to you about your wants and needs he should be able to set you up with a set.
Old Aug 24, 2023 | 10:57 AM
ok thanks for the info. hope to do lots to truck this winter, as i have sold the 3/4.
Old Aug 25, 2023 | 04:44 AM
Rug_Trucker's Avatar
5 Year Member
My VE has been at his shop for getting close to 3 months. I was told 6 weeks. I am there there are other places that can mod these pumps.
My research SAC marine nozzles are designed to run with a steady throttle setting. VCO type should be cleaner.
Old Aug 25, 2023 | 10:19 AM
u2slow's Avatar
Hungry diesel?
I put a fuel pin and 3200 spring in mine, and took the collar off the power screw so I could max it out.
edit: I'd probably use NW Fuel injection, DieselTuff, or BD Power because they're somewhat local, and freight to/from the USA is punishing.
Old Aug 25, 2023 | 04:58 PM
5 Year Member
Hungry diesel?
Yep, Eric at THD. I sent my IP to him VIA USPS in 2 2.5 gallon Hepfty Zip locks.
Grant31781
Jan 3, 2018 07:20 AM
torqmonster
Jan 18, 2010 05:04 PM
joelegs1000
Oct 17, 2006 11:04 AM
charliex25
Aug 29, 2006 08:02 PM
