1992 Dodge D250 Power window thread
Old Mar 9, 2021 | 09:16 AM
JamieA's Avatar
I installed a new Window Regulator and power window motor in my 1992 Dodge D250 LE truck this weekend. I read every thread I could find to walk me thru process. I also replaced all channel trim and window trim so everything as it relates to my power window is new.
I am stumped on 2 items:
1.) If I wind window down it sinks far into door and the wheel on the regulator comes out of the track. Should there be a stopper here that would not allow the wheel to roll out of the track?
2.) Motor is strong and everything tracks correctly but I still need to help my window as it goes up. I realize trim is new but I am thinking when I bolted my window motor to the regulator I could have tightened the spring more. Is there a setting or guideline I should go by when mounting window motor to the regulator....
Any help is is appreciated - thanks
Old Mar 9, 2021 | 10:14 AM
nonrev's Avatar
10 Year Member
IIRC there should be a window bump stop to keep it from going all the way down.. and the after market channel trim is tight, I would use silicone spray in the channel to see if it would help the window slide easier.. don't use w-d 40 it makes the rubber swell
Old Mar 9, 2021 | 10:24 AM
JamieA's Avatar
Any idea what that bump stop looks like or where it is attached ? Thanks
Old Mar 9, 2021 | 10:52 AM
nonrev's Avatar
10 Year Member
Right below where the door handle attaches inside the door
Old Mar 10, 2021 | 10:03 AM
JamieA's Avatar
Thanks for the pictures - somehow that piece is not in my door so I will have to fabricate something or put a stopper on the track somehow that would limit the down travel on the window and ensure slider ball on regulator does not come out of track.
Old Mar 10, 2021 | 02:48 PM
edwinsmith's Avatar
Have you checked to see if it isn't broken off and laying in the bottom of the door?
Old Mar 10, 2021 | 02:53 PM
JamieA's Avatar
I did look I wish it was there..... I am assuming the piece is screwed in thru the bottom of the door and either riveted or welded to the inside side door panel.
Old Mar 11, 2021 | 06:28 AM
nonrev's Avatar
10 Year Member
You can see in the first pic the upper is riveted .. I didn't look to see about the bottom. Maybe A local junk yard might have the piece you are looking for, or you could always give Oliver a shout he might have have one in a bad door.
Old Mar 11, 2021 | 08:09 PM
samiam4's Avatar
I have a junked door you can have it. Driver's side.
manual says to use bolts and nuts. I put nutplates on mine and use 10-32 screws. It's pretty easy. Note the fsm is wrong. Do it with the glass down. There's a youtube video.
Michael
Chad E. Stewart
Nov 3, 2015 01:01 AM
bannerd
Jan 5, 2014 03:27 PM
j_martin
Jul 15, 2012 11:26 PM
petrecca8
Mar 2, 2010 01:24 PM
Snapper
Oct 16, 2007 06:48 PM
