$.02 needed!!!
$.02 needed!!!
Hey guys just wondering why my top end speed is only 75 wot with the wind pushing. my signature has everything that is done to the truck. Any help is appreciated.
If this is a condition that's just come up, I'll say that on a lot of the 12 valve trucks I've looked at for low power complaints, they haven't been capable of achieving wide open throttle due to linkage wear or misadjustment. Good place to start looking.
Mine was 75 until I put in my 3200 spring and removed the throttle stop for high rpm. I'm well over 90mph now.
Given a tire size of 32.83" and a rear-end gear ratio of 3.54. The Getrag's OD (5th) gear ratio is 0.77. Final drive is 2.72:1. Calculations say that at 71.8mph, the engine is turning 2,000RPM. The stock governor spring limits fueling to 2,500RPM and usually begins to defuel shortly before then.
No I haven't done the gov. Spring yet, just gotta get myself worked up to pulling the pump top off don't wanna booger Anything up. But I figured that with the added rpms it would give me a little more top end.
My speedometer is about 5% slow, so when my needle says I am doing just a hair under 75, 75X1.05=about 79.
I can bring my speedometer up to just about 80, so I'm guessing a previous owner swapped gears, and /or you're not getting full throttle travel at the pump.
