1st Gen All Products Sell all of your 1st gen products here. This includes trucks, parts, accessories etc.
Mark this thread as Unsold
Engine & Drivetrain 1st gen parts '89-'93…about anything.
Old 12-31-2018, 05:10 PM
  #256
Drake Whitton's Avatar
Hey Oliver, I was curious if you might have a tilt steering coulmn laying around or possibly a non tilt. Basicly just needed a turn signal switch but figured I might want to swap to a tilt column.
thanks, Drake
Drake Whitton is offline
Old 12-31-2018, 09:17 PM
  #257
Received 1,637 Likes on 1,112 Posts
thanks, Drake
Lol.. Yeah, I'm sure he's got them.
How many do you want ? A dozen or two?
lol
NJTman is offline
Old 01-01-2019, 09:53 AM
  #258
Received 2,392 Likes on 1,576 Posts
Drake, I do have a bunch of 1st gen steering columns hanging in my shop.
The steering columns change through out the years, so I would need info about your truck.
A '89 column is not a bolt in match for a '93. Heck even the turn signals vary in the same year.
I tried to install a delay wiper multifunction turn signal switch on my '91.0 and it instantly blew fuses. I needed to locate another two speed wiper style multi function switch for it to work correctly.
PM me with details about your truck and we can go from there.
oliver foster is online now
Old 01-01-2019, 01:50 PM
  #259
Boostin302's Avatar
Would you happen to have drivers side door guts? (Latch, rods etc etc). Dont need anything for the power windows.
also need the exterior door handle. It's all for a 93 D250.
Boostin302 is offline
Old 01-10-2019, 03:17 PM
  #260
oliverbutthead's Avatar
How about the speed sensor for a W250? Need the connector (that plugs into the sensor) and two pieces in the upper left of this photo
oliverbutthead is offline
Old 01-11-2019, 01:55 AM
  #261
mason reinke's Avatar
Would anyone know why my 24v has lack of power the gas can be all the way down in 5th gear and I can only go about 60-65 unless I’m going down hill then I go faster I changed fuel pump and everything filter. I don’t know what it could be everything sounds great just lack of power
mason reinke is offline
Old 02-02-2019, 11:27 AM
  #262
I'll pass on trying to answer a vague, run on sentence / question from a dude at 3 AM.... posted in the wrong section.
If anyone needs some 1st gen parts to keep their truck on the road, let me know.
Thanks DTR!
Old 02-03-2019, 02:40 PM
  #263
MrFusion's Avatar
What?! Don't want to answer vague run on sentence type questions?? Must be that your crystal ball is broken!
MrFusion is offline
Old 02-17-2019, 07:47 PM
  #264
Gumby79's Avatar
Fraged my 518 last night looking for the 618 adaptor, and associated swap parts. Looking to hold more power and Lockup TQ
tilt wheel column
odo/speedometer.
Dreem Big Chisle Down To Reality
Gumby79 is offline
Old 02-17-2019, 10:14 PM
  #265
Gumby,
You are looking for what I call the 47 RH transmission as an upgrade?
Would you need a 2wd or 4x4 one?
Or do you need just the adapter plate, starter and kick down cable and you plan on getting a fresh rebuilt transmission and torque converter?
You need a complete, tilt steering column for a '92/'93 Dodge I am guessing?
You need the ODO and speedo stuff for the transmission?
or the dash cluster?
Send me a little more detailed PM as I am sure I have most if not all the parts here in the shop.
Thanks,
Oliver
Old 03-01-2019, 06:54 AM
  #266
canfield's Avatar
89 d350 tv cable
looking for a tv (kickdown) cable for a 1989 dodge Ram D350 Cummins.
canfield is offline
Old 03-04-2019, 08:53 AM
  #267
Let me see what I can dig up in the shop canfield.
canfield (03-04-2019)
Old 03-28-2019, 08:05 AM
  #268
Coller's Avatar
46RH Valve Body
How much for a good 46RH valve body. I also need a good 46RH Overdrive Governor weight, (the brass one).
Coller is offline
Old 03-28-2019, 08:33 AM
  #269
PM sent on 46RH
Old 03-30-2019, 10:16 PM
  #270
Robert Freeland's Avatar
Broken governor lever...
Would you by chance have a VE pump? Or one for parts? I managed to break my governor lever...
Robert Freeland is offline
Quick Reply: Engine & Drivetrain 1st gen parts '89-'93…about anything.
