Mark this thread as Unsold
Engine & Drivetrain 1st gen parts '89-'93…about anything.
#256
Hey Oliver, I was curious if you might have a tilt steering coulmn laying around or possibly a non tilt. Basicly just needed a turn signal switch but figured I might want to swap to a tilt column.
thanks, Drake
thanks, Drake
#257
Received 1,637 Likes
How many do you want ? A dozen or two?
lol
#258
Drake, I do have a bunch of 1st gen steering columns hanging in my shop.
The steering columns change through out the years, so I would need info about your truck.
A '89 column is not a bolt in match for a '93. Heck even the turn signals vary in the same year.
I tried to install a delay wiper multifunction turn signal switch on my '91.0 and it instantly blew fuses. I needed to locate another two speed wiper style multi function switch for it to work correctly.
PM me with details about your truck and we can go from there.
#261
Would anyone know why my 24v has lack of power the gas can be all the way down in 5th gear and I can only go about 60-65 unless I’m going down hill then I go faster I changed fuel pump and everything filter. I don’t know what it could be everything sounds great just lack of power
#262
I'll pass on trying to answer a vague, run on sentence / question from a dude at 3 AM.... posted in the wrong section.
If anyone needs some 1st gen parts to keep their truck on the road, let me know.
Thanks DTR!
Thanks DTR!
#264
Fraged my 518 last night looking for the 618 adaptor, and associated swap parts. Looking to hold more power and Lockup TQ
tilt wheel column
odo/speedometer.
Dreem Big Chisle Down To Reality
tilt wheel column
odo/speedometer.
#265
Gumby,
You are looking for what I call the 47 RH transmission as an upgrade?
Would you need a 2wd or 4x4 one?
Or do you need just the adapter plate, starter and kick down cable and you plan on getting a fresh rebuilt transmission and torque converter?
You need a complete, tilt steering column for a '92/'93 Dodge I am guessing?
You need the ODO and speedo stuff for the transmission?
or the dash cluster?
Send me a little more detailed PM as I am sure I have most if not all the parts here in the shop.
Thanks,
Oliver
Thanks,
Oliver
#267
Let me see what I can dig up in the shop canfield.
canfield (03-04-2019)
#269
PM sent on 46RH
