1st Gen All Products Sell all of your 1st gen products here. This includes trucks, parts, accessories etc.
Mark this thread as Unsold
Engine & Drivetrain 1st gen parts '89-'93…about anything.
Old 05-11-2018, 09:03 AM
  #211
Received 2,392 Likes on 1,576 Posts
Sorry Jungle.
I have been stupid busy the past 6 weeks trying to get my projects done in my small windows of free time.
I don't believe I have a cruise 88/89 steering column with a good cruise stalk. If I find something I will PM you.
oliver foster is online now
Old 05-12-2018, 04:23 AM
  #212
Jungle's Avatar
I'm looking for the whole column assembly.
Jungle is offline
Old 05-25-2018, 04:30 AM
  #213
Angry Johnny's Avatar
Ollie, do you have any crew cab rear door panels? I need a right rear 70's style or a left and right 80's style would work also. Thanks.
Angry Johnny is offline
Old 05-29-2018, 09:26 AM
  #214
PM sent to AJ
Old 06-03-2018, 05:38 PM
  #215
93allblack's Avatar
Any chance you have the clamps for the trans heat exchanger? Broke a bolt on one of mine.
Thanks.
93allblack is offline
Old 06-12-2018, 09:53 AM
  #216
nothingbutdarts's Avatar
Oliver, I sent you a PM. Thanks!
nothingbutdarts is offline
Old 06-22-2018, 10:04 PM
  #217
bigblue70's Avatar
Fan pulley
Looking for a fan pulley, Cummins number 3917674
bigblue70 is offline
Old 06-23-2018, 08:06 AM
  #218
I know I would have the earlier NON intercooled fan pulleys.
I might have an intercooled one ['91.5-'93] left on the shelf as well.
Old 06-25-2018, 09:03 PM
  #219
Old Diver's Avatar
Oliver,
I PM’d you a few days ago in response to your post on my thread regarding a Instrument Panel Cluster housing. Did you get my PM?
Then I found this thread in the Classified Forum so I thought I’d post a request here.
I need the cluster, but I also need some additional parts for a first gen.
The Electronic Temperature Cycling Switch for the A/C .
P/N- 56005783 –
This switch mounts on the A/C line bracket in front of the Evaporator/Heater housing. It has a thermo probe that slips into the A/C evaporator suction Pipe.
Oil Filler Tube. P/N- 04429611 –
This is the vertical tube on the front of the engine where you add oil. I need only this tube, but could use the cap also. Mine is kind of beat up.
If you want to sell the tube as an assembly with the connector that attaches to the timing cover, I’d buy it that way.
At the risk of being repetitive:
Housing for the instrument cluster. P/N- 56003420 –
Made of white plastic, it contains the speedometer and other instruments. It mounts to the Dash with 5 screws. On ours, the three screw holes at the top front are broken off. I need a part with good mounting holes and tabs.
The housing we need is for the 1990 to 1993 trucks that have the electronic speedometer and instruments, NOT the cable driven speedo with the 12V/constant voltage controlled instruments.
All our instruments are good, so we only need the housing. However, I you want to sell the complete cluster, we would buy that.
Thanks, Hoping to hear from you,
Jack Dancoe
Old Diver is offline
Old 06-26-2018, 08:21 AM
  #220
PM sent to Jack.
Thanks
Old 07-06-2018, 10:45 AM
  #221
cougar's Avatar
Would you happen to have a complete 518/205 wiring harness in good shape? Darn squire got to mine.
cougar is offline
Old 07-07-2018, 07:57 AM
  #222
PM sent to cougar on the harness I have in the shop.
Old 07-20-2018, 10:00 AM
  #223
Anyone need any hard to find parts to fix up their old 1st gen.?
Old 07-23-2018, 07:06 PM
  #224
Hemi Cat's Avatar
Looking for 5 speed trans for 93 2 wheel drive.
Hemi Cat is offline
Old 07-25-2018, 07:54 AM
  #225
PM sent to Hemi Cat
Quick Reply: Engine & Drivetrain 1st gen parts '89-'93…about anything.
