Wiring help, Cruise control
Old Aug 7, 2009 | 12:20 PM
solfish's Avatar
Question Wiring help, Cruise control
I have a 1998 12V that I converted from a 47RE to a NV4500. I would like it it I could get my cruise control to work. The cruise control light comes on but doesn't set speed.
I was told that the speed sensor is in the rear end, but the 47re had a output sensor on the back of it. The NV4500 only has backup light wires on it.
Old Aug 7, 2009 | 12:28 PM
infidel's Avatar
'98s are so much different electrically than the other 12 valves.
If I'm not mistaken the ground speed signal that the computer uses comes from the rear differential sensor under 30 mph and from the tranny or t-case when faster.
Sounds like you somehow need a sensor on the tranny.
Wonder if your ABS works too.
Old Aug 7, 2009 | 03:24 PM
solfish's Avatar
I guess I need to find a 98 12v with a stock manual to figure it out.
ET RAM
27
Nov 13, 2009 03:19 PM
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
nailhead
Apr 4, 2006 10:44 PM
TexasDiesel
Dec 27, 2002 10:47 AM
