Who got the best 66mm turbo??
Old 01-29-2008, 08:44 PM
Tate's Avatar
Originally Posted by dieselman2300
I was reading on Comp. Diesel that some of those guys are using a 181/131 hybrid delivery valve.
Still doesn't seem to be much info on this. A dyno test would be interesting. Hard to see how the base makes much difference.
Old 01-29-2008, 11:49 PM
stock600's Avatar
Thanks for the info, you say very laggy, maybe the extra fuel from the full cuts will help spool better, thats my plan. And being its track only i could care a less about the extra smoke. Just want a solid tune up that works well. Are you running an auto or stick truck, i will run a 2 spd. glide so hopfully i can boost it up good against the brakes and convertor to get past the lag. 15-20 lbs + should get it up in its sweet spot correct, at what psi would you say it comes in hard?
19Fury69
18
01-23-2009 10:11 PM
kelownadiesel
68
06-06-2008 06:40 PM
getblown5.9
42
02-04-2007 09:23 AM
emfc_22
10-28-2006 11:56 PM
PourinDiesel
0
11-27-2005 03:53 AM
Quick Reply: Who got the best 66mm turbo??
