Wheel Bearing Nuts?
Old Jan 2, 2003 | 07:31 PM
Alec's Avatar
Wheel Bearing Nuts?
Sorry folks -- I know I saw this somewhere here, did a search, and can't find it:<br><br>Part numbers for the old wheel bearing nuts and lockwasher for the spicer 70 rear axle. Does anyone have these to hand? Also, is there a similar improvement that can be made to the front hubs?<br><br>Thanks!<br><br>Alec
Old Jan 3, 2003 | 12:41 PM
DieselDaze's Avatar
Re:Wheel Bearing Nuts?
I dont have an answer for you.<br>But you might want to PM one of the guys on this site that have a 1st gen truck.<br><br>Perhaps Okiebroncrider may be able to help you. <br><br>Good luck.<br><br>Rich<br><br><br><br>P.s. - Once you get this information, you may want to pass it along to Gonzo so he can place the info into the Tech Facts section.<br>--- Just a thought.<br><br>Rich
Old Jan 4, 2003 | 06:29 PM
mymaur's Avatar
I had to replace one the those seals on my 2wd 95. That nut is a b$*&amp;h. No one had the correct size. &amp; If those that did, such as Sears, the socket wall was too thick. So, I found a socket at NAPA, it is a 2 1/2&quot; 6 sided socket. It is not a perfect fit. But it does the job. I think it was about 32 bucks. I am sure snap-on has one that fits perfect. But I ususally have to get a mortgage on the house to buy anything from snap on. You will probably just need a new seal. Fairly easy job, once you get the brake drum off.<br><br>Good luck.<br><br>Gary
Old Jan 4, 2003 | 06:46 PM
Haulin_in_Dixie's Avatar
Yep Napa is the only source that I could find. Mine is not 2 1/2 though it is 2 7/16, cost the same. The wharehouse said that they are a hot item, no one sells them.
silverbullet02
Oct 5, 2009 12:16 PM
Wilbur01
Aug 3, 2009 11:16 PM
Lightweight
Jan 12, 2007 06:57 PM
Copenhagenjunkie
Dec 18, 2003 03:17 PM
blackboat
Sep 23, 2003 09:18 PM
