What's TOO hot for coolant temps?
Old Jun 27, 2009 | 07:35 PM
Mcc2430's Avatar
Thank's in advance for any responses that can hepl me out. I searched for an answer but couldn't find anything definitive.
I have moved to San Antonio, TX, and when I lived in North Dakota I replaced the factory t-stat with the NAPA zero bypass. Up there I never had a problem. On the drive from Amarillo to San Antonio I was towing a 8' x 10' U-Haul trailer with a total weight of about 2000lbs. The stock temp guage was hovering between the 9 and the 0 of the 190. That was in 90-95 Degree temps with the A/C on. If there was a hill the needle would climb to the middle of the 0.
It started to scare me a little because this was highway. When I got into the city it stayed in the 0. I've only owned the truck in ND and I still have the original t-stat.
Is that TOO HOT? I can change it back if it is I just need to know if I'm going to cause damage if I continue to run the truck at that temp.
Again Thanks.
Old Jun 28, 2009 | 10:14 AM
infidel's Avatar
You can cruise at 210° all day without problem.
220° and I'd pull over and let it cool down.
Old Jun 28, 2009 | 02:20 PM
JohnX's Avatar
I have pegged my needle twice while towing heavy. Gauge all the way up, light on, chime beeping.
I stopped immediately and let the truck idle til it cooled. I have never seen a problem with it from those occasions. But I try not to make a habit of running it hot either.
Old Jun 29, 2009 | 09:03 PM
Mcc2430's Avatar
Thanks Guys. I had hoped I would be ok. I don't like messing w/ the radiator system if I don't have to.
RockysInMyBlood
Dec 9, 2008 05:35 PM
Strjock81
16
Dec 12, 2007 09:53 AM
01smoker
Aug 25, 2006 06:20 PM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
