What rear axel?
Old Nov 15, 2004 | 09:24 PM
Rganser's Avatar
What rear axel?
Picking up a 94 2500 2wd tomorrow, what rear axel would that have? I need to get a posi unit so i can actually move around in the rain and snow.
Ryan
Old Nov 15, 2004 | 09:56 PM
dalton4's Avatar
Lift the hood and look for a placard in center of hood above the grill. This will give equipment info for the truck which should include the axle ratio.
The ratio will be 3:54 or 4:10.
Old Nov 16, 2004 | 11:35 AM
CTD NUT's Avatar
All 94 2500's will have a Dana 70 rear with 1.5" 35 spline shafts and will most likely have the 3.54 gears as 4.10 was an option that was not included in every model. Go with the carrier that the factory included in Dana 70's: a Dana powr lok. IMO, it's the strongest and most durable limited slip you can buy.
Old Nov 16, 2004 | 02:24 PM
INJECTOR JACK's Avatar
It may have the locker in it already it should say no spin or something like that on the build decal.
Old Nov 16, 2004 | 02:53 PM
MikeR's Avatar
I'm quite certain the Dana 70 is 32 spline, and the Dana 80 is 35 spline. No not all 2500's come with only Dana 70's. Here's the breakdown:
2500 with auto trans; Dana 70
2500 with manual trans; Dana 80
3500 both trans; Dana 80
If I remember correctly, the 4.10 gears automatically came with a limited slip.
The 3.54's was standard as an open diff, limited slip was optional.
Old Nov 16, 2004 | 05:34 PM
Rganser's Avatar
Ill have to get out there and look at it, it is a 5 spd, but i didnt think it was a 80 ill have to look in the morning when its light out.
Ryan
Old Nov 16, 2004 | 05:37 PM
It will say 70 or 80 on the housing
Old Nov 16, 2004 | 06:20 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
Dana 70HD or Dana 80 doesnt matter.
The reason i say this is because the carriers are the same all you need to tell us is the ratio, 3.73 is the split. then if it turns out to be an 80 with 3.54's you get a Power Lok for a Dana 70HD 3.54 bore the ring gear bolt holes out ot the larger bolts.
When removing the open carrier and installing the LSD Pull the spacers out of the diff that are between the carrier barrings and the housing the LSD doesnt use them an open carrier does. (same as an AMC model 20 when changing from open to LSD)
You'll be good to go.
Plus sometimes it is cheaper getting the Dana 70 Power Lok than trying to get a Dana 80 diff too especially since Dan spicer discontinued production on the power Lok and the automatic service replacement now is a bolt together trash lok (Trac Lok) which they will tell you is a better LSD. To each thier own, there is a reason i figured out how to put the Dana 70HD power Lok into my dana 80 over the factory trac lok, predictability/manners on the snow was a big factor.
You'll have a dana 80 (unless someone changed it) since yours is a 1994 5spd 2wd also 94 was back to the 35 spline rear axles in the 70's and 80's for dodges. 93 last year of the 70 32spline
Dusty
Old Nov 16, 2004 | 07:50 PM
Rganser's Avatar
it is a 3.54, so i will look for a 3 series LSD for a dana 70 and see what i can find. Just so i understand, a dana 70 and 80 use the same carriers?? Wierd.
Ryan
Old Nov 17, 2004 | 08:47 AM
CTD NUT's Avatar
Ryan
Only a 70 HD and a 80 share carriers. Standard 70 carriers are smaller and do not interchange with the HD. Over the years, there have been about 3 different 70 carrier styles that do not interchange, so it is very important when ordering a carrier for a 70 that you correctly identfy the axle. This can be done by getting the #'s off the ring gear.
sullivad
13
Dec 18, 2006 08:47 AM
moneyman
Sep 30, 2003 09:18 PM
JImbo1
Apr 9, 2003 07:46 AM
yz
Nov 25, 2002 06:04 PM
yomitch
Nov 22, 2002 12:11 AM
