What mph does your 97' 12valve auto shift out of first
Old Dec 3, 2007 | 10:19 PM
Ronco95's Avatar
WCBCRUZER,
When you shift manually, you allow the pump in the trans to create higher pressure thru higher engine RPM. I believe that is a good thing. Higher pressure holds the clutches with more force and helps prevent them from slipping during shifts.
One of the hi performance mods to an auto is to increase internal pressure to help prevent clutch slippage during shifts.
I have a Suncoast v/b that increases pressure and well as an updated seal within the trans to hold higher pressure without leaking.
One more point, with higher pressure, the T/C clutch is capable of higher input torque without slipping when locked.
Ronnie
Old Dec 5, 2007 | 01:17 AM
wcbcruzer's Avatar
Makes sense Ronco. But would it be ok in the long run to constantly manually shift like that? Sounds like it's being hard on parts.
Ok, I found a better pic, hoep this helps:
Old Dec 5, 2007 | 12:41 PM
turboman1's Avatar
Thanks for the help ill try adjusting it this weekend maybe if i have the time
Thanks Adam
Old Dec 5, 2007 | 12:45 PM
Mcmopar's Avatar
Originally Posted by turboman1
Anybody know what i can do to make it shift out of 1st at 12-15mph and see how my mpg changes?
Thanks Adam
Buy a stronger 1-2 shift spring.
Tractor Truck
Aug 25, 2010 03:57 PM
treemonkey
Jun 17, 2009 02:06 AM
97catintenn
Aug 24, 2005 06:01 PM
Mark Hodowanec
Nov 13, 2004 11:02 PM
Mark Hodowanec
Nov 10, 2004 06:41 PM
