What Know
Old Jul 3, 2008 | 10:03 PM
diesel_man98's Avatar
Unhappy What Know
My 96 blew a head gasket I know for sure between cylinder 2-3 know I put another head on it and new cummins head gasket and still has a miss and blows compression out the intake sound like a dead miss just like when the head gasket was blown I torqued it in correct sequence and 89ftlb+90* what else. Is a flattened lob on the cam a possibility anyway need advise and your thoughts on my problem thanks
Old Jul 4, 2008 | 06:31 PM
John_P's Avatar
diesel_man:
I am not clear on your post on how you said you torqued the cylinder head.
As I recall, with the stock headbolts, it is 90ft.lbs PLUS a quarter turn. Is that what you did? By your post it looks like 89ftlbs PLUS another 90 after that????
John_P
Old Jul 4, 2008 | 11:51 PM
thats 89 ft lb + 1/4 turn or 90 degrees thats what my manual shows still should have ran right for a minute, but new head and gasket and it still misses and blows back out the intake I took it back off and the gasket looks fine all the push rods seem straight what next step to resolve my problem
Old Jul 5, 2008 | 12:42 AM
oldblues's Avatar
hi
look at your intake valve springs as 1 may be week or broken ?
bent intake valve , pour some diesel fuel in your intake port and see if it runs out under intake valve ?
bad injector , have them tested ?
let us know !
Old Jul 5, 2008 | 02:00 AM
dieselman2300's Avatar
I vote for a pushrod either not seated right or your valve adjuster backed itself out. Dont ask me how I know, scared the poop out of me when it happened.
Old Jul 5, 2008 | 08:53 AM
thank I'll check that stuff and let yall know
Old Jul 5, 2008 | 10:14 AM
John_P's Avatar
diesel_man:
Thanks for your reply. Looks like that shouldn't be the problem then.
The other DTR Members are giving you some good advice on things to look for. One other thing I would add along the lines of what oldblues has told you, is to put a dial indicator on the valvetrain and make make sure you have the proper clearances on those valves opening and closing AFTER you adjust those valves again. I set my mine @ 10 on the intake and 12 on the exhaust.
John_P
Old Jul 5, 2008 | 05:47 PM
Thanks to all of you for the good advice it ended up be a valve adjustment I did it before but I guess I over looked one #3 exhhaust was to tight and wasn't closing I did the overhead again 10 int and 20ext and it runs fine thanks everyone
Old Jul 5, 2008 | 06:37 PM
John_P's Avatar
diesel_man:
That is indeed good news! Glad to hear it was something simple! It is amazing how a problem like that can make your mind and heart "race" when it comes up, and how relieved you are when it is something simple!
John_P
Old Jul 5, 2008 | 07:19 PM
They were surely racing Im happy It was something small I usually isnt for me Thank you again for paying attention and for the great knowledge
bglz42
Apr 7, 2007 07:30 PM
sakisaki400
Apr 5, 2007 11:08 PM
Jezzhuntin
Oct 13, 2006 06:34 PM
PurNLoud
Sep 8, 2006 11:40 PM
JKM
Jul 3, 2005 04:59 PM
