water pump
Old Jun 13, 2010 | 08:06 AM
95twotone's Avatar
water pump
hey fellas i think my water pump is going out because it is starting to leak and i have a squeel from that area. Is that what it is and how hard are they to change. Yhank you
Old Jun 13, 2010 | 12:05 PM
G1625S's Avatar
Probably coming out the weep hole in the pump. Time for a change. It is by far the easiest water pump ever. No gasket, just o-ring. It'll take longer to take the belt on and off then it will to swap the pump. Check the tensioner while you're in there-it could be the cause of the squeak...
Old Jun 14, 2010 | 10:15 AM
infidel's Avatar
Only tip is to make sure the old o-ring comes off.
Sometimes they stick to the block and look like metal.
Two o-rings and they leak.
Old Jun 17, 2010 | 06:45 AM
Mainemike100's Avatar
As stated above, probably the easiest water pump to change. I was happy that it was a quick repair.
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
