Wastegate discussion
Gentlemen,
I installed a four inch exhaust system and seemed to immediately lose waste gate operation. I have to feather the throttle to keep boost down on my stock WH1C with the stock 12CM housing.
Is it possible that wastegate will not regulate my set up or is there something else wrong? I also want to relocate my boost elbow to the compressor housing and need some silicone hose to do that with. Where can I get that hose from?
I will pull the turbo off and pressurize the wastegate actator to check operation. If the actuator is moving, I will assume the wastegate is working properly.
Any other suggestions?
Thanks in advance!
Ronnie
Thanks in advance!
Ronnie
Don't pressurize the wastegate with more than about 30 psi of compressed air.
I can't count how many folks who have blown out the diaphragm with full compressor pressure.
Your new exhaust system should have made no difference in the wastegate operation unless maybe you tweaked something during installation.
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
B1 Power Wagon
May 19, 2003 09:00 AM
