Does a 3k GSK give more HP/TQ?
Old Dec 29, 2008 | 11:47 AM
Maddog411's Avatar
I was reading on citydiesel.net that it gives 50-100 HP...I can see that maybe in the top end where you won't be fighting the fuel cutoff that starts with the stock governor springs but does it give more power throwout the rpm range?
Old Dec 29, 2008 | 12:27 PM
JohnX's Avatar
Only on the top end like you thought. I don't see how it would affect anything under about 2500 rpm.
Old Dec 29, 2008 | 06:52 PM
infidel's Avatar
A GSK gives you more usable hp.
Without the GSK your higher rpms are basically useless.
Old Jan 9, 2009 | 12:40 PM
offroad's Avatar
I installed mine along with a #10 plate so I'm not sure what the GSK by itself did but the two of them together made it feel like a whole new truck.
Old Jan 9, 2009 | 01:46 PM
dstad's Avatar
the 3k gsk is the best thing we ever did to my dadsa truck. almost 80 out of od
Old Jan 9, 2009 | 03:06 PM
robert chilton's Avatar
You will make more power down low also. Mostly more usable power up top but the GSK does affect the govenor at lower speeds. My 3GSK fuels hard to about 2500RPM then starts the downhill slide. I need to put the 4k spring back in.
Old Jan 9, 2009 | 04:13 PM
Dartmouth 12V's Avatar
If you are going for dyno numbers, the 3k GSK won't make a ton of difference. However, it does make a lot of difference when towing. It gives you a wider usable rpm range which means that you can enter the next gear at a higher rpm. Putting one in will allow upshifts on hills where you previously could not.
Old Jan 9, 2009 | 10:59 PM
greg@Lockitup's Avatar
Very good point.
SHARPMACHINE
Mar 6, 2007 08:45 AM
12valve
Dec 29, 2005 11:40 AM
plow
Aug 9, 2005 04:25 PM
MR HYDROSEED
Mar 9, 2005 10:49 PM
Got Smoke?
Oct 26, 2004 03:57 PM
