wastegate
Old Sep 12, 2015 | 01:52 PM
dirty dozen's Avatar
wastegate
Can anyone tell me a way to tell if my wastegate is stuck open? My acuator doesn't work but I'm thinking my wastegate my be partially or fully open. Thanks in advance.
Old Sep 12, 2015 | 03:15 PM
j.fonder's Avatar
guessing this is an hx-35w turbo? does it have a v-band flange on the back? if so, you can unbolt the downpipe and look inside the exhaust housing at the wastegate(little flapper looking deal). you'll probably need a little inspection mirror to see in there.
easier methods would be to clamp a vice grip onto the actuator "shaft" and work it back and forth to see if the gate opens and closes. the actuator should hold the wastegate shut. if you have any doubt remove the actuator and just tie-wire the gate shut
Old Sep 12, 2015 | 07:37 PM
Originally Posted by j.fonder
guessing this is an hx-35w turbo? does it have a v-band flange on the back? if so, you can unbolt the downpipe and look inside the exhaust housing at the 1wastegate(little flapper looking deal). you'll probably need a little inspection mirror to see in there.
Yep its a hx-35 and it does have a v band on the hot discharge side. I'll check it out thanks.
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
dieselcrazy
Mar 22, 2003 08:21 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
